[Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update
I try to install Isaac Sim in Omniverse, but came across the error as list below. plz help me !
my environment is
WIN11+WSL+UBUNTU18.04+RTX3080
my driver info is
sam@LAPTOP-0T9VKD6Q:~/Downloads$ nVidia-smi
Fri Mar 18 14:54:03 2022
| NVIDIA-SMI 510.52 Driver Version: 511.79 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:01:00.0 On | N/A |
| N/A 42C P8 20W / N/A | 506MiB / 16384MiB | 4% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 92 G /Xwayland N/A |
my install log
2022-03-18 06:34:48 [1,220ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_EXTENSION_NOT_PRESENT
2022-03-18 06:34:48 [1,220ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2022-03-18 06:34:48 [1,220ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2022-03-18 06:34:48 [1,220ms] [Info] [gpu.foundation.plugin]
2022-03-18 06:34:48 [1,393ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_EXTENSION_NOT_PRESENT
2022-03-18 06:34:48 [1,393ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2022-03-18 06:34:48 [1,393ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2022-03-18 06:34:48 [1,393ms] [Info] [gpu.foundation.plugin]
2022-03-18 06:34:48 [1,393ms] [Warning] [omni.gpu_foundation_factory.plugin] RT-capable GPU not found, switching to compatibility mode
2022-03-18 06:34:48 [1,393ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation!
2022-03-18 06:34:48 [1,393ms] [Error] [omni.kit.renderer.plugin] GPU Foundation is not initialized!
2022-03-18 06:34:48 [1,393ms] [Info] [carb] Initializing plugin: omni.ui.windowmanager.plugin (interfaces: [omni::ui::windowmanager::IWindowCallbackManager v0.3]) (impl: omni.ui.windowmanager.plugin)
2022-03-18 06:34:48 [1,393ms] [Info] [carb] Initializing plugin: carb.imgui.plugin (interfaces: [carb::imgui::ImGui v1.0]) (impl: carb.imgui.plugin)
2022-03-18 06:34:48 [1,393ms] [Info] [carb] Initializing plugin: carb.imguizmo.plugin (interfaces: [carb::imguizmo::ImGuizmo v1.0]) (impl: carb.imguizmo.plugin)
2022-03-18 06:34:48 [1,393ms] [Error] [omni.kit.imgui_renderer.plugin] Invalid device attached to the default window!
2022-03-18 06:34:48 [1,396ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.test-0.0.0] (order: 0) Triggered by: omni.command.usd-1.0.1, omni.graph-1.0.0, omni.graph.examples.python-1.0.0, omni.isaac.dynamic_control-0.1.8, omni.isaac.gamepad-0.1.4, omni.isaac.lula-0.1.0, omni.isaac.motion_planning-0.1.7, omni.kit.primitive.mesh-1.0.0, omni.kit.search_core-1.0.0, omni.kit.usd_undo-0.1.0, omni.kit.widget.imageview-1.0.1, omni.kit.window.extensions-1.0.2, omni.kit.window.imageviewer-1.0.5, omni.physx.tests-1.3.14-5.1, omni.services.core-1.1.1, omni.ui-2.5.3, semantics.schema.editor-0.2.2 (path: /home/sam/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.test)
2022-03-18 06:34:48 [1,396ms] [Info] [omni.kit.app.plugin] [1.426s] [ext: omni.kit.test-0.0.0] startup
Hi. Currently, Vulkan is not supported on WSL/WSL2. We recommend running Isaac Sim natively or on a remote server.
OK, thanks
