I am using Omniverse Create v2021.3.8 on AWS Windows Virtual Machine. I’m getting the error while enabling the webrtc client extension.
Please find the attached log file for the same.
Error -
kit_20220421_070441.log (610.6 KB)
022-04-21 07:05:27 [Error] [carb] [Plugin: carb.livestream-rtc.plugin.dll] Could not load the dynamic library from c:/users/administrator/appdata/local/ov/pkg/create-2021.3.8/kit/plugins/carb_gfx/carb.livestream-rtc.plugin.dll. Error: The specified module could not be found.
2022-04-21 07:05:27 [Warning] [carb] Potential plugin preload failed: c:/users/administrator/appdata/local/ov/pkg/create-2021.3.8/kit/plugins/carb_gfx/carb.livestream-rtc.plugin.dll
2022-04-21 07:05:27 [Error] [omni.ext.plugin] [ext: omni.kit.livestream.webrtc-0.1.0] failed to load native plugin: c:/users/administrator/appdata/local/ov/pkg/create-2021.3.8/kit/plugins/carb_gfx/carb.livestream-rtc.plugin.dll
2022-04-21 07:05:27 [Error] [carb] [Plugin: omni.kit.livestream.plugin] Dependency: [carb::livestream::Vision v0.3] failed to be resolved.
2022-04-21 07:05:27 [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::kit::livestream::ILivestream (pluginName: nullptr)
At:
c:\users\administrator\appdata\local\ov\pkg\create-2021.3.8\kit\exts\omni.kit.livestream.webrtc\omni\kit\livestream\webrtc\scripts\extension.py(10): on_startup
c:/users/administrator/appdata/local/ov/pkg/create-2021.3.8/kit/plugins/bindings-python\omni\ext\impl_internal.py(143): _startup_ext
c:/users/administrator/appdata/local/ov/pkg/create-2021.3.8/kit/plugins/bindings-python\omni\ext\impl_internal.py(174): startup_all_extensions_in_module
c:/users/administrator/appdata/local/ov/pkg/create-2021.3.8/kit/plugins/bindings-python\omni\ext\impl_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2):
c:\users\administrator\appdata\local\ov\pkg\create-2021.3.8\kit\exts\omni.kit.window.extensions\omni\kit\window\extensions\ext_commands.py(30): do
c:\users\administrator\appdata\local\ov\pkg\create-2021.3.8\kit\extscore\omni.kit.commands\omni\kit\undo\undo.py(74): execute
c:\users\administrator\appdata\local\ov\pkg\create-2021.3.8\kit\extscore\omni.kit.commands\omni\kit\commands\command.py(235): execute
c:\users\administrator\appdata\local\ov\pkg\create-2021.3.8\kit\exts\omni.kit.window.extensions\omni\kit\window\extensions\utils.py(47): toggle_extension
c:\users\administrator\appdata\local\ov\pkg\create-2021.3.8\kit\exts\omni.kit.window.extensions\omni\kit\window\extensions\ext_components.py(79): toggle
c:\users\administrator\appdata\local\ov\pkg\create-2021.3.8\kit\exts\omni.kit.window.extensions\omni\kit\window\extensions\ext_components.py(89):
2022-04-21 07:05:27 [Error] [omni.ext.plugin] [ext: omni.kit.livestream.webrtc-0.1.0] Failed to process python module extension in ‘c:/users/administrator/appdata/local/ov/pkg/create-2021.3.8/kit/exts/omni.kit.livestream.webrtc/.’.
