cimig
#1
We can run /usr/local/driveworks/bin/sample_canbus_logger --driver=can.aurix --params=ip=10.42.0.146,bus=a
and we get a stream of CAN messages from the device connected to CAN1 on the harness.
But running /usr/local/driveworks/bin/sample_canbus_logger --driver=can.aurix --params=ip=10.42.0.146,bus=b
the process terminates without showing any CAN messages.
for bus=b, we get the following error.
104828400 ERROR DW_NOT_AVAILABLEEndpointUDP: stopped
whereas we get “EndpointUDP: started 10.42.0.146:50000” for bus=a (CAN1 on harness)
We confirmed there are continuous CAN messages from the device on CAN2 using a CAN/USB device.
The data rate is 500kb/s
We need to view the CAN data on the PX2
cimig
#2
When I switch the device to CAN1 on the harness, I get the following error.
AurixCAN: lost clock sync between Aurix and Tegra clock. Tegra clock is ahead of Aurix clock by at least 908877672 msec
SteveNV
#3
Dear cimig,
For time sync between Aurix and Tegra clock, please refer to the following link.
https://devtalk.nvidia.com/default/topic/1031778/faq/drive-px2-time-sync-guide/
And then please try to run the app again.
I could run the app w/o any error like below. Thanks.
nvidia@nvidia:/usr/local/driveworks/bin$ sudo ./sample_canbus_logger --driver=can.aurix --params=ip=10.42.0.83,bus=b
[sudo] password for nvidia:
Program Arguments:
–driver=can.aurix
–filter=000:000
–hwtime=1
–params=ip=10.42.0.83,bus=b
–send_i_understand_implications=0
–send_id=6FF
Initialize DriveWorks SDK v0.6.67
Release build with GNU 4.9.2 from v0.6.0-rc7-0-g51bd3aa against Vibrante PDK v5.0.5.0
TimeSource: monotonic epoch time offset is 1484388267289061
SDK: Resources mounted from /usr/local/driveworks-0.6/data/resources
nvrm_gpu: Bug 200215060 workaround enabled.
SDK: Create NvMediaDevice
egl::Display: found 2 EGL devices
egl::Display: use drm device: drm-nvdc
SDK: number of GPU devices detected 2
SDK: currently selected GPU device discrete ID 0
SAL: identified board as DrivePX2-TegraA
SensorFactory::createSensor() -> can.aurix, ip=10.42.0.83,bus=b
Cannot setup CAN message filters: DW_NOT_IMPLEMENTED
EndpointUDP: started 10.42.0.83:50000
^CEndpointUDP: stopped 10.42.0.83:50000
SDK: Release NvMediaDevice
Driveworks SDK released
nvidia@nvidia:/usr/local/driveworks/bin$ sudo ./sample_canbus_logger --driver=can.aurix --params=ip=10.42.0.83,bus=a
Program Arguments:
–driver=can.aurix
–filter=000:000
–hwtime=1
–params=ip=10.42.0.83,bus=a
–send_id=6FF
SensorFactory::createSensor() -> can.aurix, ip=10.42.0.83,bus=a
