How to read CAN 5 and 6 through AURIX
I’m trying to redirect CAN messages on CAN 5 and 6 though AURIX. In your documentation DS-07982-001_v06.pdf on page 41 says that 0-6x CAN (A-F): Aurix and Tegra (4 Aurix only, 2 shared), also on page 35 there is a diagram how they are connected.
For a test I used your canbus_logger sample, and tried to run it (./sample_canbus_logger --driver=can.aurix --params=ip=10.42.0.146,bus=e) but I get an error:
" AurixCAN: expected bus={a,b,c,d} to be set to a valid CAN bus
Driveworks exception thrown: DW_INVALID_ARGUMENT: AurixCAN: bus parameter is invalid"
I was reading your documentation but I can’t find a way to redirect the messages through AURIX …
Is there a document somewhere or guidlines how to do that?
Thanks in advace,
Anja
Dear anja,
Could you please help to check below link for your topic? Thanks.
Dear Steve,
Tnx for the quick answer. I already tried this guide and it works for the Aurix bus a,b,c and d perfectly, but for e and f it gives the error I mentioned above (" AurixCAN: expected bus={a,b,c,d} to be set to a valid CAN bus Driveworks exception thrown: DW_INVALID_ARGUMENT: AurixCAN: bus parameter is invalid").
Is there a difference between accessing those two buses (e and f) on Aurix?
Dear anja,
Could you please refer to below link for your question?
Anja,
Did you encounter the clock drift / synchronization errors when setting up the Aurix? What version of driveworks do you have installed on your host / target?
