Why it is showing like this ?
Save pin changesverlay
Hi Dnyaneshwar_3D,
Are you using Jetson Nano with eMMC module or SD module?
Please share the detailed steps how you used Jetson-IO.
its an Jetson Nano developer kit i have flashed sd card using flashing software balena Etcher .
Jetpack version is R32.7.1 JDP 4.6.4
i have used this command :- sudo /opt/nvidia/jetsion-io/jetson-io.py
then this window open as SPI interface i selected SPI1 and try to save it
It’s not matched with my understanding…
Please share the result of the following command on your board.
$ cat /etc/nv_tegra_release
After you save the configuration in Jetson-IO, it should perform a reboot to apply the change.
It seems you are using Jetpack 4.6.4 (with L4T R32.7.4).
