Error in testing demo (Cart Delivery)
hi,when i runing the demo cart-delivery i got error as follows after press “PLAY”
2020-07-21 11:30:25 [1,110,527ms] [Error] [omni.isaac.dynamic_control.plugin] DcWakeUpArticulation: Invalid or expired articulation handle
2020-07-21 11:30:25 [1,110,527ms] [Error] [omni.isaac.dynamic_control.plugin] DcSetDofVelocityTarget: Invalid or expired dof handle
ENVIRONMENTS:
ubuntu18.04
isaac_sim(docker image:nvcr.io/nvidia/isaac-sim:2020.1_ea)
GPU:RTX 2080Ti
nvidia-docker
Is there anything showing in the viewport, or did it fail to load the models?
it has successfully loaded the models and started the Robot Engine Bridge.and when i use nvidia-docker run the demo,both of isaac_sim and isaac_sdk,there is an error in connecting them on port 55001 and 55000.
i have fix the error by change file /isaac_sim/_build/linux-x86_64/release/exts/omni.isaac.robot_engine_bridge/resources/isaac_engine/json/isaacsim.app.json in docker image and add -p 55000:55000 when runing the isaac_sim image.
there is the content of json file
“name”: “isaacsim”,
“modules”: ,
“graph”: {
“nodes”: [
“name”: “interface”,
“components”: [
“name”: “ledger”,
“type”: “isaac::alice::MessageLedger”
“name”: “input”,
“type”: “isaac::alice::TcpSubscriber”
“name”: “output”,
“type”: “isaac::alice::TcpPublisher”
“name”: “time_sync”,
“type”: “isaac::alice::TimeSynchronizer”
“edges”:
“config”: {
“interface”: {
“input”: {
“port”: 55001,
“host”: “IP of your isaac_sdk
“output”: {
“port”: 55000
I am running Isaac Sim on my local machine (Alienware). And when I run JetBot Sample Application, everything works fine till I git the play button. On the terminal I get the following messages/errors scrolling down the screen.
And of course I can not move the Jetbot using the keyboard awsd keys.
Any help would be appreciated.
Please see this related topic:
Try method #1 (Package) when creating the Isaac folder on the Nucleus server.
Thank you. It was Nucleus Server and Isaac Asset issue. Followed the instruction carefully again and it works now.
Thank you again.
NX
