I’ve used Omniverse to export Unreal levels out of Unreal and into Houdini. Is it possible to export animated meshes out of Sequencer as a .usd file?
Yes, you can export animated files out of Unreal to USD. If you do an export level to Omniverse, it should export everything- including the sequencer.
Thank you so much for the reply! I’ll give it a try!
