Failed to install Isaac Sim 2022.2.0 on win11-home
I tried to install Isaac Sim 2022.2.0 by omniverse launcher.
At the end, intire of the progress bar became green but the installation cnt not completed.
It takes several hours and keep frozen.
Would you please help to resolve the problem?
PC information is as the following.
CPU: AMD Ryzen 9 7900X 12-Core Processor 4.70 GHz
Mem: 32GB
OS : Windows 11 Home (21H2)
Output of command
| NVIDIA-SMI 526.98 Driver Version: 526.98 CUDA Version: 12.0 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce … WDDM | 00000000:01:00.0 On | N/A |
| 0% 45C P8 16W / 220W | 1049MiB / 8192MiB | 5% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1728 C+G …me\Application\chrome.exe N/A |
| 0 N/A N/A 6828 C+G …wekyb3d8bbwe\Video.UI.exe N/A |
| 0 N/A N/A 7284 C+G C:\Windows\explorer.exe N/A |
| 0 N/A N/A 8492 C+G …n1h2txyewy\SearchHost.exe N/A |
| 0 N/A N/A 8516 C+G …artMenuExperienceHost.exe N/A |
| 0 N/A N/A 10756 C+G …2txyewy\TextInputHost.exe N/A |
| 0 N/A N/A 12848 C+G …s\Win64\EpicWebHelper.exe N/A |
| 0 N/A N/A 13240 C+G …IA Omniverse Launcher.exe N/A |
| 0 N/A N/A 14936 C+G …n64\EpicGamesLauncher.exe N/A |
| 0 N/A N/A 15108 C+G …y\ShellExperienceHost.exe N/A |
| 0 N/A N/A 16036 C+G …462.54\msedgewebview2.exe N/A |
| 0 N/A N/A 16792 C+G …ext\CNext\AMDRSSrcExt.exe N/A |
| 0 N/A N/A 16852 C+G …ropbox\Client\Dropbox.exe N/A |
| 0 N/A N/A 17612 C+G …\CNext\RadeonSoftware.exe N/A |
| 0 N/A N/A 19504 C+G …462.54\msedgewebview2.exe N/A |
| 0 N/A N/A 23172 C+G …ge\Application\msedge.exe N/A |
| 0 N/A N/A 23892 C+G …e\PhoneExperienceHost.exe N/A |
Best regards.
Hi. Which GPU are you using?
Please share the omni.isaac.sim.post.install.log in the Isaac Sim package folder while the installation is frozen or the Isaac Sim log files if available.
Does Create and Code able to install and launch successfully?
Hi @hayashi-l , were you able to resolve the issue? if not, then please share the information as requested by Sheikh to resolve the issue
