Feasibility to convert ROS based LiDAR object detection code to Driveworks format using Point Cloud Processing API
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[*] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Pegasus DevKit (E3550)
other
SDK Manager Version
[*] 1.7.1.8928
other
Host Machine Version
[*] native Ubuntu 18.04
other
Is it feasible to convert a ROS based LiDAR object detection code with publishers and subscribers sending actuation signals based on live LiDAR point cloud data into Driveworks format using Point Cloud Processing API?
Dear @raji,
Does that mean, you are looking for integration of DW + ROS code? Or you have lidar recorded data using ROS and want to use in DW code?
Dear @SivaRamaKrishnaNV ,
We don’t want to reinvent the wheel and with minimal changes to ROS based env code to work with Driveworks API.
We want our algorithm to process live lidar data and send actuation signals based on the algorithm’s detection.
Please let me know if I’m unable to understand your question correctly.
Our algorithm is working for live LiDAR data and also sending actuation signals to DBW vehicle. We want to replicate the same thing using Driveworks.
So how should we proceed in general?
  1. if we want to convert the ROS environment based code to Driveworks environment then do we need to change the code completely?
  2. Can Point cloud processing API process the live lidar data then perform object detection/segmentation and send actuation with the help VehicleIO module?
Please confirm if my understanding is correct.
Dear @raji,
There is no publishers/ subscribers mechanism in DW. You need to use SAL APIs to read sensor data. You may check Lidar samples to know about API usage.
  1. Can Point cloud processing API process the live lidar data then perform object detection/segmentation and send actuation with the help VehicleIO module?
Point cloud processing API can perform operations given at DriveWorks SDK Reference: Point Cloud Processing on lidar data. We don’t have object detection algorithm APIs based on lidar data. You may have to implement object detction DNN model based on lidar data and use DW DNN module to integrate into DW.
