Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
In the early stage of our project we want to use the kit in a simulated environment first.
So we need to feed in sensor data (camera and lidar) from an external simulation program (without real sensors connected).
My questions are:
Is it possible to feed in images and sensor data generated in an simulated, external environment over the network and use them as input for the examples and emit the results?
Are there any recommendations / examples dealing with scenarios without real hardware connected to the dev kit?
Is it possible to use ROS on the Drive Dev Kit for example to embed it in an existing simulation environment?
thanks for your reply.
We studied the systems on the link that you posted, but it seems that for us this system will not be available.
That’s why I asked the questions above… ;)
Is there a known way to integrate an interprocess communication or use ROS for feeding in virtually generated sensor data?
Later on, we want to use the system in a real car environment, but at the beginning we have to use it in our simulator.
We are using the CARLA simulator and a TCP based IPC. Since we cannot inspect the Drive OS before a purchase, I ask here. Unfortunately, I have not yet been able to clarify these questions on the basis of the documentation.
Yes; we plan to generate images and data with the simulator and want to process them on a Drive Developer Kit. Therefore, we would like to feed data from the simulation into the dev kit.
