Fehler Meldung SDK Manager Flashen
We have the following problem we get an error message:
"There is not enough free space to install the selected SDK.
Please select a different installation folder or delete the space and try again. "
There is different memory on the PC.
We also have access to the folder and this hat 32gb
Hi hoffmannsascha,
We have identified the issue and will fix it in the upcoming SDK Manager 1.3 release.
For now, you’ll need a larger disk space to continue the installation. Thanks.
how large
when is the version coming?
It needs about 30GB (for flashing) + displayed disk space requirement.
If everything goes smoothly, should be later this month.
