I am using the latest sdk manager (v1.1.0-6343)
I have mounted a hard disk to my home directory and it has available space of 243GB.
from df -h:
Filesystem Size Used Avail Use% Mounted on
/dev/sdb4 473G 208G 243G 47% /home
However the sdkmanager GUI complains:
There is not enough disk space to install the selected SDK.
Please select a different install folder or clear disc space and try again.
I have a separate disk for home and root. Not sure if this causes a problem? Is there a way to flash the PX2 without the space check?
Thanks in advance.
Regards,
Linn
