I used the SDK Manager 1.2.0.6738 to install the Jetson SDK components ,is’t need 3GB space.
The download folder have the 500GB(new disk) , BT, the SDK show “There is not enough disk space to install the selected SDK.Please select a different install folder or clear disc space and try again”
Hi lxy,
The download directory and install directory are different. Can you please check if the disk where install directory exists also has enough space?
In this screenshot, I could see that
- download directory is set to /media/gcs/work,
- Install directory is set to /home/gcs/nvidia/nvidia_sdk
Can you please double check if /media/gcs/work has enough disk space?
