I have TX2i module that has jetpack 4.4.1 installed. so I wanted to upgrade the Jetpack 4.6 which is the latest release, so I had to upgrade SDK Manager from 1.5.1 to 1.7 so i can install latest version of jetpack. and since the upgrade of SDK manager i can’t upgrade the jetpack and it keep either showing me this error message.
This is the error log in terminal window.
11:04:39 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
11:04:39 SUMMARY: VisionWorks on Host - host: Install completed successfully.
11:04:39 SUMMARY: NVIDIA Nsight Graphics - host: Install completed successfully.
11:04:39 SUMMARY: NVIDIA Nsight Systems - host: Install completed successfully.
11:04:39 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
11:04:39 SUMMARY: File System and OS - target_image: Install completed successfully.
11:04:45 ERROR: Flash Jetson TX2 - flash: *** Reading ECID … *** Error: ECID read failed.
11:04:45 ERROR: Flash Jetson TX2 - flash: command terminated with error
11:04:45 SUMMARY: Flash Jetson TX2 - flash: First Error: Jetson board is in a bad state and cannot be recovered. Please manually put board to recovery mode again and retry… The Jetson target is in a bad state and cannot be flashed. Please manually put the target into recovery mode and then retry flashing.
11:04:45 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
11:04:45 SUMMARY: Multimedia API - target: Depends on failed component
11:04:45 SUMMARY: TensorRT on Target - target: Depends on failed component
11:04:45 SUMMARY: VisionWorks on Target - target: Depends on failed component
11:04:45 SUMMARY: VPI on Target - target: Depends on failed component
11:04:45 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
11:04:45 SUMMARY: cuDNN on Target - target: Depends on failed component
11:04:45 SUMMARY: OpenCV on Target - target: Depends on failed component
11:04:45 SUMMARY: NVIDIA Nsight Systems - target: Depends on failed component
11:04:45 SUMMARY: DateTime Target Setup - target: Depends on failed component
11:04:50 SUMMARY: CUDA on Host - host: Install completed successfully.
11:05:09 ERROR: VPI on Host - host: |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
11:05:14 SUMMARY: VPI on Host - host: Install completed successfully.
