Flash Jetson TX2 stuck at connecting
I’m trying to flash the jetson tx2 using the newer SDK manager 1.8.0.10363 but when I get to the step which is setting the username and password it says connecting and it stucks there forever. Here is the screenshot:
The host is Ubuntu 18.04.6.
Not sure if there was networking issue at that time, have you flashed the device successfully before? Could you try again now?
Hi JaTxGPU,
Please select Manual Setup - Jetson TX2 and try again.
Yes I did but not with this SDK where there are two modes : automatic and manual.
Okay I’ll try that thank you
