I’m new to TX2.And the picture is problem i faced ,when i flash TX2 with SDK Manager.
I use natively installed host PC Ubuntu 18.04.
My hardware is TX2(4GB).
Can someone tell me how to solve this problem? Thanks!
Are you sure the Jetson is in recovery mode at that point? If so, then are you using the supplied USB cable? Other “charger” cables are known to have low quality for use in data and I’d say 3 out of 4 “charger” cables fail for the purpose of flashing. You are using a native Ubuntu host PC, so there shouldn’t be any problem with a VM issue (people using a VM is the most common cause of this, but you’ve eliminated that as a cause).
