Flash
Is it the username and password used when registering an Nvidia account?
Is it the username and password used when registering an Nvidia account? I tried many times and it still shows wrong username and password
What is going on and how to solve it?
no;
if a monitor is connected to the jetson it will display so named “initial Ubuntu configuration setup scree”
there password username and network settings could be set up;
then they will be used as at the screenshot above.
Thanks,
In other words, when flashing the TX2, you must use the monitor, right?
not at all; but you must complete the configuration defining user & password.
Many ways could be used to get it done.
But, I used a virtual machine, and did not define the username and password configuration when I flashed the machine.
no, the credentials have’t been set; that is the reason why it is not possible to use the credentials;
once the credentials are set up it will be possible to use then to install the components using the sdkmanager
Do:
  1. conenct display and local keyboard
  2. boot Jetson
  3. setup credentials
  4. return to the step at the scrennshot
