I am on Debian Lenny and am trying to in stall PGI Fortran compiler 9.01. I get two errors:
(1) FLEXlm hostid is empty. Unfortunately, we cannot generate license without hostid.
(2) ERROR: Linker : not found
localrc has not changed
Any pointers?
Thanks, Jan
Here is the full output:
Installation directory? [/opt/pgi]
/srv/pgi
Installing software into /srv/pgi (this may take some time).
Making symbolic links in /srv/pgi/linux86/9.0
Making symbolic links in /srv/pgi/linux86-64/9.0
Do you wish to install MPICH1?(y/n)n
For further information, please go to FAQ | PGI.
Do you want the files in the install directory to be read-only? [y,n]
Installation complete.
If you purchased a software subscription, please note that the ST
support services to you are limited to the terms described in the
file /srv/pgi/SUBSCRIPTION_SERVICE. A copy of this file
can be found at http://www.pgroup.com/support/SUBSCRIPTION_SERVICE.
Please check the FAQ at FAQ | PGI for a
current listing of customer support concerns, including installation,
use of PGI software, and other questions or problems.
This product uses the STLport Standard Template Library for ANSI C++.
The STLport license can be found at STLport: License Agreement.
