I compiled the nvidia-edk2 to remove some logs and change boot logo however I didn’t find how to force an UEFI password in the uefi bin to avoid manual operation through the menu, is there a way to do that ?
Hi romain.julian,
Are you using the devkit or custom board for Orin NX?
What do you mean about “UEFI password”?
Do you want to customize UEFI to have the password to prevent end-user entering into UEFI menu manually?
If so, we don’t have similar feature currently as my understanding.
You can try to remove the function in UEFI to remove the feature to interrupt the boot and enter into UEFI menu.
Please refer to Close or hide UEFI menu - #3 by KevinFFF for details.
Hello, thank you for you response, let me give a little more informations.
I’m on a custom carrier board but tried the same operations on devkit.
What I can do now is at startutp i press ESC button
I then select “Device Manager” menu
Then User Password Management menu
Then I press “Change Admin Password” and I set password.
This work fine and achieve what I want .However , my problem is that I would like to set this password programmatically without need first human action. Is there any way to do that?
I don’t see such option for “User Password Management menu” in Device Manager menu as following.
Please also check if Skipping oem-config can meet your requirement to pre-configure the username/password.
Sorry for the delay not much time to work on this recently.
The UEFI is not customized currently even if the final goal is to customize it.
oem-config if I understood well the process is for linux username and password so it’s not a solution for my problem.
Please find here the photos of my UEFI menu, if that help, I flashed the jetson with official tools, using l4t_initrd_flash.sh script with a JETPACK 6.1.
Okay, may I know what’s your use case for this password?
Do you mean that you want to pre-configure this password before flash?
Maybe you can customize UserAuthenticationSmm.c for your use case.
Use case is to allow our production team to customize some parameters if needed but to avoid final user to change them.
Thank you for your response will try to customize UserAuthenticationSmm
