Gpio can not out low in physic
i change pn.01
in gpio dts
gpio_main_default:default{
from gpio-input to gpio-output-high
in pinmux dts
from
pull low ,enable tristate, enable input
to
pull none,disable tristate,disable input
but i use /sys/class/gpio echo out > direction echo 0 > value ,and use multimeter to meature voltage ,but it is high
hello user49922,
could you please refer to developer guide, Changing the Pinmux.
you may see-also this section, Identifying the GPIO Number to check the GPIO allocation ranges for each GPIO group.
