young
1
My development environment is as follows.
- Hardware Platform - Custom Jetson Xavier NX
- JetPack Version - 4.5
- L4T - 32.5
I want to change HDMI_DDC_SCL’s clock.
I know to change the clock with the following command:
cat /sys/bus/i2c/devices/i2c-0/bus_clk_rate
echo 400000 > /sys/bus/i2c/devices/i2c-0/bus_clk_rate
Where do I need to modify the Kernel source?
May I know what is your purpose to change this value?
The clock-frequency in the device tree should be able to change this.
young
4
HDMI EDID is not recognized by certain monitors.
The recommended frequency for the level shift chip is 400kHz. (nx custom board)
young
5
Confirmed.
It was in a file in the following path:
But making corrections requires thought.
hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi
