Hello, There seems to be mismatch between the design guide and the devkit 3509 about the SDA and the SCL lines. According to the design guide: HDMI SCL 90/98 HDMI SDL 92/100
on the devkit design its HDMI SCL 100 HDMI SDL 98
which is correct?
Hi, the devkit schematic is correct. We will check the Design Guide and correct it, thanks.
is there a way to swap the pins by SW? my board designed by the design guide
No. You might need to swap pin connection.
