Hello guys, thank you for reading. I’m trying to get pointcloud from RSD455 asset of isaac sim, but it won’t work.
This is my code.
create_prim("/World/Realsense_bottom", "Xform")
bottom_parent = stage.GetPrimAtPath("/World/Realsense_bottom")
UsdGeom.XformCommonAPI(bottom_parent).SetTranslate((-0.09938172401020395, -0.02812370593180794, 0.9132709956171814))
# bottom_quat = [0.9829, 0.0, 0.1841, 0.0]
euler_bottom = (0,21.21749,0)
UsdGeom.XformCommonAPI(bottom_parent).SetRotate(tuple(euler_bottom))
# create_prim_with_ref("/World/Realsense_bottom/RSD455", realsense_asset_path)
# sensor_bottom = stage.GetPrimAtPath("/World/Realsense_bottom/RSD455")
create_prim_with_ref("/World/Realsense_bottom", realsense_asset_path)
sensor_bottom = stage.GetPrimAtPath("/World/Realsense_bottom")
# UsdGeom.XformCommonAPI(sensor_bottom).SetTranslate((0, 0, 0))
rb_bottom = UsdPhysics.RigidBodyAPI.Get(stage, sensor_bottom.GetPath())
if rb_bottom:
rb_bottom.CreateRigidBodyEnabledAttr().Set(False)
else:
for child in sensor_bottom.GetChildren():
rb_child = UsdPhysics.RigidBodyAPI.Get(stage, child.GetPath())
if rb_child:
rb_child.CreateRigidBodyEnabledAttr().Set(False)
camera_depth = Camera(
prim_path="/World/Realsense_bottom/RSD455/Camera_Pseudo_Depth",
frequency=10,
position = (0,0,0),
resolution = (640,480),
name="Camera"
camera_depth.initialize()
camera_depth.add_motion_vectors_to_frame()
camera_depth.add_distance_to_image_plane_to_frame()
while simulation_app.is_running():
world.step(render=True)
for _ in range(10):
time.sleep(0.1)
# Now retrieve the sensor data.
rgb_image = camera_rgb.get_rgb()
depth_image = camera_depth.get_depth()
# intrinsics = camera_rgb.get_intrinsics_matrix()
# Convert the depth to a point cloud.
# pc, _ = depth2pc(depth_image, intrinsics, rgb_image)
pointcloud = camera_depth.get_pointcloud()
# # Visualize with Open3D.
pcd = o3d.geometry.PointCloud()
pcd.points = o3d.utility.Vector3dVector(pointcloud)
o3d.visualization.draw_geometries([pcd])
break
simulation_app.close()
And I get this error
File "/home/rcv/Desktop/ws_voxposer/scene_standalone.py", line 242, in <module>
File "/home/rcv/anaconda3/envs/isaac-sim/lib/python3.10/site-packages/isaacsim/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/camera.py", line 1023, in get_pointcloud
pointcloud = self.get_world_points_from_image_coords(points_2d, depth.flatten())
File "/home/rcv/anaconda3/envs/isaac-sim/lib/python3.10/site-packages/isaacsim/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/camera.py", line 1461, in get_world_points_from_image_coords
raise Exception(
Exception: pinhole projection type is not set to be able to use get_world_points_from_image_coords method which use pinhole prespective projection.
I would be really thankful for any help.
Thank you.
