Hello. I wonder if its possible to create world space ui.
Hi weeys,
I’m not sure I understand, are you referring to world space manipulators vs local space? If that is the case, you can hit “W” to switch between the two modes. You can also click and hold on the move or rotate icon (left toolbar in Create) to switch modes.
Hope this helps!
Hi @vbrisebois,
What I mean is to place UI like graphs, buttons, text in 3D space instead of on the Omniverse Create UI.
Example below (With text in 3D/World Space)
