How to completely delete a prim?
Isaac Sim Version
5.1.0
Operating System
Ubuntu 24.04
GPU Information
  • Model: RTX 5080
  • Driver Version: 580.95.05
Topic Description
Detailed Description
Why are these prims lingering in my Stage after I deleted them? How can I get rid of them?
Steps to Reproduce
  1. Delete a prim from the stage
Screenshots or Videos
What I’ve Tried
Right Click → Delete
@rwalia you aren’t able to delete those prims since the source USD (lab_copy) is referenced as a composition arc. by deactivating the prims, you are effectively removing those prims from your current stage without breaking the ancestral prim/hierarchy in your source USD. if those prims need to be removed for good any time you reference the source USD, it’s best to open up the source USD and delete those prims directly.
another non-destructive way to do this AND keeping your stage not cluttered with these deactivated prims is using the filter to hide those inactive prims (by unticking Show Inactive Prims). This will leave the source USD intact while keeping the stage visually optimized:
Filtering is the perfect solution for my case. Thank you so much!
