How to configure PCIe EP on Orin Dev Kit 64GB using r36.1 Release.
There is some info with r35.1 here - Jetson AGX Orin Platform Adaptation and Bring-Up — Jetson Linux<br/>Developer Guide 34.1 documentation
Not sure its latest with 5.15 kernel.
Please advise.
kayccc
4
Thank You,
Follow the suggested step :Where change below line from this :- p3767.conf.common
ODMDATA=“gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g”;
to this -
ODMDATA=“gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-1,hsio-uphy-config-0,gbe0-enable-10g”;
xxx@xx:~/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
=> sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
Notice, device didnt come up/failed to boot up, No boot up screen or any logs.
Is there anything that am missing here ?
Any pointers to configure ORIN Dev KIT as a PCIe EP ?
Looks like just updaing ODMDATA wont help & has issues with R36.1
Can some one confirm, as I unable to login to Dev Kit when confingure it as EP, is this expected ?
36.3 fixed this issue. Please upgrade the BSP.
Yes already switched to 36.3. Thank You
system
Closed
12
