I’m sorry if this is a stupid question but I have difficulties setting my RTX Lidar properly.
First, I’m using IsaccSim 5.0.0 on Ubuntu 22.04
In my stage I have a model with 4 RTX Lidar Example_rotary_2d placed in the front/left/right/rear of the model. I’ve edited the lidar startAzimuthOffset, validStartAzimuthDegree and validEndAzimuthDegree in order to not have a 360 degree Lidar sensor.
Right now I’m using RViz with LaserScan in order to see what/where the 4 lidar are hitting but the result doesn’t seems right.
It would be easier if I could see the laser beam directly inside IsaacSim but I’m not seeing any DrawLines or equivalent attribute.
Can you please tell me how to do it? Is there a way to visualize the Lidar beam?
Just to add some context my model has been added to the stage as a reference and the model in my USD file is facing -Y axis.
There are a few standalone example you can refer to, for example, standalone_examples/api/isaacsim.ros2.bridge/rtx_lidar.py.
In this example, it creates both the point cloud debug draw pipeline and laser scan debug draw pipeline in Isaac Sim using Isaac Debug Draw Point Cloud.
Hi
Thank you for your reply and sorry for the delay.
I’ve checked the link you provided.
I’ve copied the standalone_examples/api/isaacsim.ros2.bridge/rtx_lidar.py content and paste it to the Window/Script Editor but after clikcing on the Run button, I’ve got the following error:
ImportError: cannot import name ‘SimulationApp‘ from ‘isaacsim‘ (unknown location)
Hi @ludokun, the rtx_lidar.py is a standalone example and you don’t need to start the Isaac Sim GUI first to run it.
You need to use python.sh to run it. ./python.sh /path/to/isaacsim-5.0.0/standalone_examples/api/isaacsim.ros2.bridge/rtx_lidar.py
