In drive PX2, driveworks version 0.6, gmsl camera,
I would like to know simple way to fix the camera exposure to modify the tool(recorder-qt) parameter.
The parameters used are
camera-type=ar0231-rccb-ss3323,csi-port=ab,camera-count=4,output-format=h264,async-record=0,fifo-size=12, record-frame-count=1, frame-skip-count=1, required-framerate=20
Then, there seems to be a way to fix the exposure using ipp_raw.
Can I use ipp_raw to sync the 4ch camera image and save the data?
Dear @ehduk,
Is the version you mentioned “DRIVE OS 5.0.10.3 SDK WITH DRIVRWORKS LINUX FOR DRIVE PX2”? I can use this.
Yes.
May I know what is the issue you are facing while using DW recorder tool. Could you share sample recorded video(image) to understand the issue in DW 1.2. Note that you are supposed to use recorded tool in outside environment and not in office premises.
