I have already applied Jetpack 5.1.1, which is R35.3.1, but I still have the same issue, so I would like to try installing this patch.
I don’t know how to use the extracted files. Is it directly moved to a certain path, or is it installed using any command?
It is just installed to your BSP directory and replace some old files. But I don’t think your issue is related to this overlay…
UART serial console has nothing to do with usb.
My suggestion here is please reply the question first and I will tell you whether your issue would be fixed by the overlay firmware or not.
No need to rush in applying that overlay.
I also need to use ttyACM0 and ttyUSB0 to connect the drone
This does not reply the question. My question here is which “port” you are using physically on the carrier board. Type C port or micro usb port…
You don’t need to repeat you cannot see /dev/ttyACM0. I knew that from the beginning.
你這裡沒有回答到我的問題. 我這裡是指說你是用你底板上的哪一個port. 物理上的port… 哪一種接口… usb type C 還是micro usb port…
不用一直跟我說你看不到/dev/ttyACM0. 這個我從一開始就知道了
If you are using that pin, then I can guarantee you that your issue has nothing to do with the usb overlay…
That pin is totally not usb related thing to jetson. So usb firmware 100% won’t make anything difference.
The forum link you are referring to is not related to UART either. It is just because the type C port and uart port all become /dev/ttyACM0 on host PC side… that is why you got mislead.
What is the usecase here? You connect this UART1_TX/RX to another drone device?
Do you expect this /dev/ttyACM0 comes on jetson side or your drone side? Because every post you shared or referred on this forum is all asking about /dev/ttyACM0 on the host PC side. But your document seems to expect /dev/ttyACM0 on jetson side…
If you expect jetson side to have /dev/ttyACM0, then you may need to install some drivers from DJI… this node won’t just come out with no reason…
還有幾點需要澄清一下
請問你預期/dev/ttyACM0要生成在jetson這端還是你drone的那端? 因為你在這個forum上參考的所有post, /dev/ttyACM0都是host PC ↔ jetson連結的時候, host PC那端會生成的東西. 但現在你的文件看起來你好像是預期/dev/ttyACM0會出現在jetson這端…
