How to reset the transform
I am trying to create a machine movement for assembly CAD data using Physx. How can I reset the Transform? I couldn’t find the command.
To create movement with Physx, I need to edit the tree structure of the Stage. In the USD converted from CAD data, Xform has Transform values. When I move parts objects out of Xform or to another Xform, they undergo unwanted movements and rotations. This is the problem.
Generally, CG tools have a function to reset the Transform without changing the object’s position to avoid this issue. It is called “Reset Transform” or “Zero Transform.” Is there an equivalent command in Omniverse?
I use Isaac Sim 4.0.
Best regard.
Wondering this as well!
Please describe your issue or problem in a new topic linked to this one by selecting the “Reply as linked topic” option. Thanks.
