How to reset the coordinates of a part
I am new to Isaac Sim and am trying to import an assembly model.
However, the basic coordinates of the parts are off. (If I set x,y,z to 0, the z axis is -700 off from the other parts).
Can I re-set the part’s basic coordinates?
Hi @Hisamichi - Are you trying to import robot? if yes, use this documentation: 5.1. Import URDF — Omniverse IsaacSim latest documentation
In addition, you can follow documents from this section as well: https://docs.omniverse.nvidia.com/isaacsim/latest/gui_tutorials/index.html
I imported the parts created in Fusion360 into Isaac Sim as USD files.
Should I import them as URDF files?
Hi @Hisamichi - If you are not importing robots then no need to convert them into URDF files.
Thanks for the advice!
