How to set the multi-monitor order on the RTX A2000
Hi SIR !
Implement the RTX A2000 on your PC and connect the four mini-DP ports to the four 4K monitors.
This PC also uses the DP port on the main unit to convert it to VGA and then connects it to a VGA monitor.
The VGA monitor uses Intel graphics drivers, and the mini-DP uses NVIDIA drivers.
Connect 5 monitors from your PC, but the order of the monitors is from the left.
I want to use VGA, mini-DP1, mini-DP2, mini-DP3, mini-DP4,
The actual alignment is mini-DP4, mini-DP3, mini-DP1, mini-DP2, VGA
It will be.
It is not possible to set it to “VGA, mini-DP1, mini-DP2, mini-DP3, mini-DP4” on the OS multi-monitor sorting order setting screen.
How do I change the order set on the OS multimonitor sort order setting screen?
The following has already been implemented.
  1. Refresh the following registries
    \HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\Configuration
    \HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\Connectivity
  2. Reinstall the latest graphics driver
BEST REGARDS.
Hi SIR !
The above question is about a problem where the intended arrangement cannot be achieved when trying to rearrange four monitors.
Despite setting them as 1, 2, 3, 4 from left in the PC settings screen, when pressing the identify button in the PC’s multi-monitor settings, the monitors display as 3, 4, 2, 1.
The order is different.
Can someone tell me how to set the monitor order to match the order set on the PC?
I’d like the actual monitors to be arranged from left to right as 1, 2, 3, 4 when set as such on the PC’s settings screen.
BEST REGARDS.
