How to use MIPI IBIS model of XAVIER
HI there are two questions for using MIPI IBIS model
1 In MIPI IBIS model, PIN descriptions just contain PIN 1 (VCC) PIN2(signall), other pins are not contained. How to use the IBIS model? have any direction?
Thank you
Which file in the package do you mean? Jetson AGX Xavier S-Parameter and IBIS Models
The file is t194_bdmipi_csi_rev1p00,ibs in XAVIER_IBIS_Models
Hi, have you ever did IBIS model work? .ibs file is for V/I and V/T, and so no other pins. You can see similar content in other .ibs files.
