Currently, I’m trying to use Rviz2 with GPU by settings the following environment variable __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia, however i got these errors on docker container /tmp/.X11-unix and /tmp/.docker.xauth volume mounted.
ai@ubuntu:~$ __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia rviz2
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-ai'
[ERROR] [1756109491.419668382] [rviz2]: rviz::RenderSystem: error creating render window: basic_string::_M_construct null not valid
[ERROR] [1756109491.419858655] [rviz2]: InvalidParametersException: Window with name 'OgreWindow(0)' already exists in GLRenderSystem::_createRenderWindow at ./.obj-aarch64-linux-gnu/ogre-v1.12.1-prefix/src/ogre-v1.12.1/RenderSystems/GL/src/OgreGLRenderSystem.cpp (line 1061)
[ERROR] [1756109491.419906367] [rviz2]: rviz::RenderSystem: error creating render window: InvalidParametersException: Window with name 'OgreWindow(0)' already exists in GLRenderSystem::_createRenderWindow at ./.obj-aarch64-linux-gnu/ogre-v1.12.1-prefix/src/ogre-v1.12.1/RenderSystems/GL/src/OgreGLRenderSystem.cpp (line 1061)
[ERROR] [1756109491.419930496] [rviz2]: InvalidParametersException: Window with name 'OgreWindow(0)' already exists in GLRenderSystem::_createRenderWindow at ./.obj-aarch64-linux-gnu/ogre-v1.12.1-prefix/src/ogre-v1.12.1/RenderSystems/GL/src/OgreGLRenderSystem.cpp (line 1061)
[ERROR] [1756109491.419984576] [rviz2]: rviz::RenderSystem: error creating render window: InvalidParametersException: Window with name 'OgreWindow(0)' already exists in GLRenderSystem::_createRenderWindow at ./.obj-aarch64-linux-gnu/ogre-v1.12.1-prefix/src/ogre-v1.12.1/RenderSystems/GL/src/OgreGLRenderSystem.cpp (line 1061)
Does anyone know how to use Rviz2 with gpu? since it use a lot of CPU load.
Currently I’m using Jetpack 5.1.2 (L4T 35.4.1) due to camera driver problem.
Which device do you use?
Could you share more information about your environment?
I have the same problem. In my case, I try to display rviz2 inside Isaac ROS docker container from a remote Jetson AGX Orin machine via SSH in my ubuntu workstation.
I am able to display xclock and xeyes from inside Isaac Ros container in my workstation successfully but cannot make it for rviz2. I got similar error from the post.
Here is my jetson info from jetson_release command:
- Model: NVIDIA Jetson AGX Orin Developer Kit
- L4T: 36.4.4
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
- Module: Check with sudo
Platform:
- Distribution: Ubuntu 22.04 Jammy Jellyfish
- Release: 5.15.148-tegra
jtop:
- Version: 4.3.2
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to connect to bus: Host is down
- Service: Inactive
Libraries:
- CUDA: 12.6.68
- cuDNN: 9.10.2.21
- TensorRT: 10.7.0.23
- VPI: 3.2.4
- OpenCV: 4.5.4 - with CUDA: NO
Hi, here is my jetson_release
ai@ubuntu:~ $ jetson_release
Software part of jetson-stats 4.3.2 - (c) 2024, Raffaello Bonghi
Model: Jetson AGX Orin Developer Kit - Jetpack 5.1.2 [L4T 35.4.1]
NV Power Mode[3]: MODE_50W
Hardware:
- P-Number: p3701-0005
- Module: NVIDIA Jetson AGX Orin (64GB ram)
Platform:
- Distribution: Ubuntu 20.04 Focal Fossa
- Release: 5.10.120-tegra
jtop:
- Version: 4.3.2
- Service: Active
Libraries:
- CUDA: 12.2.140
- cuDNN: 1.0
- TensorRT: 8.5.2.2
- VPI: 2.3.9
- Vulkan: 1.3.204
Hi, both
Please make sure you have launched the container with --runtime nvidia
This plugin will mount the essential driver to allow the container to access the GPU.
I have already run with nvidia on the /etc/docker/daemon.json by default runtime with nvidia.
i have this docker compose file.
services:
jetson-moveit:
image: dockerfiles-jetson:moveit
build:
context: .
dockerfile: Dockerfile.moveit
args:
USER_ID: 1000
GROUP_ID: 1000
container_name: jetson-gpu-moveit
runtime: nvidia
env_file:
- .env
environment:
- DISPLAY=:0
- QT_X11_NO_MITSHM=1
- ROS_DOMAIN_ID=${ROS_DOMAIN_ID}
- XAUTHORITY=/tmp/.docker.xauth
- NVIDIA_VISIBLE_DEVICES=all
- NVIDIA_DRIVER_CAPABILITIES=all
- CUDA_HOME=/usr/local/cuda-12.2
- PATH=/usr/local/cuda-12.2/bin:$PATH
- LD_LIBRARY_PATH=/usr/local/cuda-12.2/lib64:$LD_LIBRARY_PATH
volumes:
- /tmp/.X11-unix:/tmp/.X11-unix:rw
- /tmp/.docker.xauth:/tmp/.docker.xauth:rw
- $HOME/moveit_ws:/home/ai/moveit_ws:rw
- /dev:/dev:rw
- $HOME/.bash_history:/home/ai/.bash_history:rw
- $HOME/.inputrc:/home/ai/.inputrc:rw
network_mode: host
privileged: true
ipc: host
tty: true
stdin_open: true
cap_add:
- SYS_ADMIN
- SYS_PTRACE
restart: always
shm_size: 8gb
but it still not able to use it./
