I want to use seeeduino (not i2c but serial communication)
in jetson nano.
So,I tried to install Additional Boards Manager of XIAO.
I looked at this site and tried.
But, I got a warning when I was installing Seeed SAMD Boards and I can’t install it.
tool bossac is not available for your operating
So, I want to know if there is a solution.
I have no knowledge of the software, and have no ability to answer. However, if I run this command I do see some software which could be installed:
apt search bossac
What it shows is:
bossa-cli/bionic 1.3~20120408-5.1 arm64
Atmel SAM ARM microcontroller flash programming utility
So perhaps if this software is what is missing, then you might be able to install via:
sudo apt-get install bossa-cli
I have no idea if this would help or not, but it might be worth researching.
