the “Figure9.12 HSIO UPHY”of“Orin-TRM_DP10508002_v1.2p.pdf” is refer to the “Table7-4 UPHY0”of Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf”
the “Figure9.13 NHVS UPHY”of“Orin-TRM_DP10508002_v1.2p.pdf” is refer to the “Table7-5 UPHY1”of Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf”
the “Figure9.14 GBE UPHY”of“Orin-TRM_DP10508002_v1.2p.pdf” is refer to the “Table7-6 UPHY2”of Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf”
Based on the provided context, it appears that you are asking about the relationship between figures in the “Orin-TRM_DP10508002_v1.2p.pdf” document and tables in the “Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf” document.
Specifically, you are asking about the following references:
- Figure 9.12 HSIO UPHY in “Orin-TRM_DP10508002_v1.2p.pdf” refers to Table 7-4 UPHY0 in “Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf”.
- Figure 9.13 NHVS UPHY in “Orin-TRM_DP10508002_v1.2p.pdf” refers to Table 7-5 UPHY1 in “Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf”.
- Figure 9.14 GBE UPHY in “Orin-TRM_DP10508002_v1.2p.pdf” refers to Table 7-6 UPHY2 in “Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf”.
These references suggest that the figures in the “Orin-TRM_DP10508002_v1.2p.pdf” document are related to the UPHY (Universal PHY) configurations described in the “Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf” document.
In the context of the Jetson AGX Orin platform, UPHY refers to the Universal PHY (Physical Layer) interface, which is a shared interface for multiple peripherals such as USB, PCIe, and Ethernet.
The Jetson Orin Nano Series Data Sheet mentions that “USB 3.2, MGBE, and PCIe share UPHY Lanes. See the Product Design Guide for supported UPHY configurations.” This suggests that the UPHY configurations described in the “Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf” document are relevant to the Jetson Orin Nano platform as well.
In summary, the references provided indicate that the figures in the “Orin-TRM_DP10508002_v1.2p.pdf” document are related to the UPHY configurations described in the “Jetson-AGX-Orin-Design-Guide_DG-10653-001v1.7.pdf” document, which are relevant to the Jetson AGX Orin and Jetson Orin Nano platforms.
Correct. The cross reference mapping is as follows.
UPHY0 = HSIO = PEX
UPHY1 = NVHS0
UPHY2 = UPHY2 (MGBE)
