Isaac Sim Assets Pack removed from the Omnivers Launcher exchange? I haven’t seen any relevant notices or documents explaining the matter
Isaac Sim Version
4.2.0
4.2.0
Please refer to Error:A requested file or directory could not be found at the time an operation was processed.
I can`t search for Isaac Sim Assets Pack on Omnivers Launcher exchange, but I was able to find it before。
They have been removed. Please access assets through the “Isaac Assets (Beta)” tab in Window-> Browsers → Content, and there is no need to download them.
Is internet necessary to access “Isaac Assets (Beta)”? How can I access assets without internet?
Yes, internet is necessary to access it. For locally access assets, you may want to try downloading them first through the content brower:
Window → Browsers → Content → Omniverse → localhost → NVIDIA → Assets → Isaac → 4.2
@VickNV, I disagree that there is no need download them. Plenty of reasons you may want to work on local assets.
Ive used this technique in v4.1, v4.0 and back into 2022, 2023. Seems like the same for other users on this post. @ltorabi, just my two cents but as user feedback I think these assets should be made available again. Please.
Hi, @VickNV , can you elaborate on this workflow please.
Here is a link to the previous documentation: https://docs.omniverse.nvidia.com/isaacsim/latest/installation/install_faq.html#assets-pack
In this new workflow, where Ive opened IsaacSim, and loaded a scene USD like SAMPLES/ROS2/carter_warehouse_apriltags_worker into a stage…
Then, I modify the assets in that scene so somehow, how should it be saved locally (lets say whole scene USD)? Just from the stage panel → Right click?
Then in a later session, I’m assuming I would just load the saved file in the Content Panel from the local folder tree on the left?
I understand if the most efficient path to resolution is simply a link to updated docs.
Thank you,
We will replace it with direct links and add new docs for its usage.
@VickNV Thank You!!!
