I can’t see the first 3 pictures you attached, could you attach them again?
Besides, what’s the host PC OS you used or using VM?
Just some info which might help…
If you use the command “head -n 1 /etc/nv_tegra_release
”, then you can find the installed L4T version. If you then go here:
https://developer.nvidia.com/embedded/jetpack-archive
…you can match your L4T release to the JetPack with compatible packages (you don’t need to flash again, just uncheck that and check your optional packages for install). Also, it is sometimes better to just use the most recent JetPack/SDKM via starting with this option (which makes older releases visible):
sdkmanager --archivedversions
(then pick the release you found matches from the first URL)
I don’t know if it is a case of just having the wrong release, but you could verify you’re using the right JetPack/SDKM with what the Jetson has installed.
