Is there anyway to import a map that has been created on Unreal Engine (along with its textures) into Isaac Sim on Linux? I am currently running Isaac Sim on Ubuntu.
Thank you for the help!
Sorry, the Omniverse Unreal Engine Connector is only available on Windows. One could use a Windows PC to export an Unreal map to Nucleus as USD and MDL, then access it from Isaac Sim on Linux.
Hi LouRohan, could you provide a more detailed tutorial for that? Thanks!
Well it means that you have to download Unreal 5.3 and Isaac Sim on a Windows PC if you want to use our connector, which works for Unreal 5.3 and down. Once you have both Unreal Version 5.3 and Isaac Sim, or USD Composer installed on the PC, go to the Laucher and also install our Unreal Connector for 5.3
