Hello :)
The company I’m working in is trying to integrate Nvidia Omniverse to our production pipeline and we’ve been experimenting a few things. One problem we’ve faced is with udims. I’m currently using Unreal Engine 4.27 and even though my udim/virtual texture is correctly connected to the material and the material correctly connected to the mesh, when I export them to a USD file, only the 1001 map shows.
Here’s my workflow: I’ve connected my udim maps, importing 3 udim maps (1001, 1002, 1003) into virtual textures (so ultimately, there’s only one virtual texture), and connected the VT to a material in UE. The instanced material is applied to my mesh and I placed the mesh in a level, saved the level, and used the “export level to omniverse” button to export the level into USD. The path I saved is “Omniverse > localhost > Projects” and when I check the exported USD file, the mesh and shaders seem okay but only the 1001 map is connected to the material. I think the problem is with the textures? The textures are automatically imported when I export the level to USD, and when I check the texture maps, they’re not virtual textures and are imported seperately. 1001, 1002, 1003 maps exists seperately so UE doesn’t recognize the textures as udims. I’ve looked at the MDL/OmniPBR shader in UE and it looks like it doesn’t support virtual textures/udims. Is there a solution to this problem?
Thank you in advance.
