Import Custom Map in Nvidia drive
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
I have created an HD Map with Roadrunner Mathworks software and exported it in an OpenDrive format. I followed the instructions in the documentation to transform it to dwMaps. However, when I try to validate it with the Driveworks Maps Inspection Tool, the map is not visible. What may the problem be?
Thanks,
Maria
Dear @siomari,
Do you see any error in terminal log? Is it possible to share map to reproduce?
My terminal log is:
[18-02-2022 09:16:25] Platform: Detected Generic x86 Platform
[18-02-2022 09:16:25] TimeSource: monotonic epoch time offset is 1644909124065366
[18-02-2022 09:16:25] Platform: number of GPU devices detected 1
[18-02-2022 09:16:25] Platform: currently selected GPU device discrete ID 0
[18-02-2022 09:16:25] SDK: Resources mounted from …/…/data/
[18-02-2022 09:16:25] Initialize DriveWorks SDK v2.2.3136
[18-02-2022 09:16:25] Release build with GNU 7.4.0 from heads/buildbrain-branch-0-gca7b4b26e65
[18-02-2022 09:16:25] Initialize DriveWorks VisualizationSDK v2.2.3136
[18-02-2022 09:16:25] Initialize DriveWorksGL SDK v2.2.3136
[18-02-2022 09:16:25] GL-SDK: initialize OpenGL
[18-02-2022 09:16:25] Maps: Reading map data from “/media/maria/KINGSTON/test.xml” …[18-02-2022 09:16:25] reading done.
[18-02-2022 09:16:25] MapSanityChecker: Checking sanity of all road segments…
[18-02-2022 09:16:25] MapSanityChecker: Road segment with 0 connections detected! (1/1)
[18-02-2022 09:16:25] MapSanityChecker: Sanity check complete.
[18-02-2022 09:16:25] Driveworks exception thrown: DW_BUFFER_FULL: LocalLayout: Capacity exceeded.
[18-02-2022 09:16:25] Building Local layout failed
The map I use:
test.txt (57.8 KB)
Hello, I also upload the OpenDRIVE(xodr)
test.xodr (8.3 KB)
test.geojson (92.4 KB)
file I export from RoadRunner and
attached a screenshot of my test road.
From my understanding, I have a problem determining the points in the geometry tag. Is there a specific way to calculate them, knowing the geo-referenced points?
Hi @siomari
Could you show me which document you followed? Please see if the following topics help on your case.
From DriveWorks SDK Reference I followed the Importing Custom Maps Data and consulted the Structs for Map Data and the dwMaps.xsd file.
I saw the links, thank you!
My question is: How can I get the lanes in coordinates of the road segment coordinate system? eg. by taking out each geopoint from the origin? is that logic right? Or should I do something different?
