Installing PyCUDA on Drive OS 5.2
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
I’m trying to follow the instructions at https://docs.nvidia.com/drive/drive-os-5.2.0.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_Development_Guide/install_tensorrt.html#wwpID0EUHA to install PyCUDA on Drive AGX Pegasus. However when I run the pip install ‘pycuda>=2019.1.1’ command, I’m getting the following error.
$ pip install 'pycuda>=2019.1.1'
Collecting pycuda>=2019.1.1
  Downloading https://files.pythonhosted.org/packages/5e/3f/5658c38579b41866ba21ee1b5020b8225cec86fe717e4b1c5c972de0a33c/pycuda-2019.1.2.tar.gz (1.6MB)
    100% |████████████████████████████████| 1.6MB 399kB/s
    Complete output from command python setup.py egg_info:
    *** WARNING: nvcc not in path.
    *** May need to set CUDA_INC_DIR for installation to succeed.
    *** I have detected that you have not run configure.py.
    *** Additionally, no global config files were found.
    *** I will go ahead with the default configuration.
    *** In all likelihood, this will not work out.
    *** See README_SETUP.txt for more information.
    *** If the build does fail, just re-run configure.py with the
    *** correct arguments, and then retry. Good luck!
    *** HIT Ctrl-C NOW IF THIS IS NOT WHAT YOU WANT
    Continuing in 1 seconds...
    Sorry, your build failed. Try rerunning configure.py with different options.
      File "<string>", line 1, in <module>
      File "/tmp/pip-build-zoxh5Y/pycuda/setup.py", line 254, in <module>
        main()
      File "/tmp/pip-build-zoxh5Y/pycuda/setup.py", line 250, in main
        zip_safe=False)
      File "aksetup_helper.py", line 24, in setup
        setup(*args, **kwargs)
      File "/usr/lib/python2.7/dist-packages/setuptools/__init__.py", line 128, in setup
        _install_setup_requires(attrs)
      File "/usr/lib/python2.7/dist-packages/setuptools/__init__.py", line 123, in _install_setup_requires
        dist.fetch_build_eggs(dist.setup_requires)
      File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 513, in fetch_build_eggs
        replace_conflicting=True,
      File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 774, in resolve
        replace_conflicting=replace_conflicting
      File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 1057, in best_match
        return self.obtain(req, installer)
      File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 1069, in obtain
        return installer(requirement)
      File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 580, in fetch_build_egg
        return cmd.easy_install(req)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 698, in easy_install
        return self.install_item(spec, dist.location, tmpdir, deps)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 724, in install_item
        dists = self.install_eggs(spec, download, tmpdir)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 909, in install_eggs
        return self.build_and_install(setup_script, setup_base)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1177, in build_and_install
        self.run_setup(setup_script, setup_base, args)
      File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1163, in run_setup
        run_setup(setup_script, args)
      File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 253, in run_setup
        raise
      File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
        self.gen.throw(type, value, traceback)
      File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 195, in setup_context
        yield
      File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 166, in save_modules
        saved_exc.resume()
      File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 141, in resume
        six.reraise(type, exc, self._tb)
      File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 154, in save_modules
        yield saved
        yield
      File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 250, in run_setup
        _execfile(setup_script, ns)
      File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 45, in _execfile
        exec(code, globals, locals)
      File "/tmp/easy_install-oCcB7W/numpy-1.20.2/setup.py", line 30, in <module>
        if nvcc_path is None:
    RuntimeError: Python version >= 3.7 required.
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-zoxh5Y/pycuda/
Am I missing something? Thanks.
Hi @kenneth.chu ,
We will take a look at this and update you. Thanks.
The section was for the general release (see Installing PyCUDA) and wrongly put into DRIVE OS documentation.
So we already removed it from the following release.
PyCUDA is an Open Source project but is not something we tested in DRIVE OS.
Sorry for any inconvenience.
