Hardware: Jetson AGX Xavier, Jetpack 5.1-b147 Deepstream 6.2
Tegra release info: `R35 (release), REVISION: 2.1, GCID: 32413640, BOARD: t186ref, EABI: aarch64, DATE: Tue Jan
Hi I want to use ROS2 as a minimal middleware solutiuon on my hardware (without instaling in fancy ways like in a Docker)
I went to the getting started page here
and it says the JP version is 5.1.2 I’m not sure if this is compatible with my setup (mentioned above)
As i Understand the version need to install is ROS2 Humble
The instructions on the buildfarm webpage says
- Set Locale
- Instlall Deps
- Setup source
and the the installation instructions
sudo apt update
sudo apt install ros-humble-ros-base
Is this sufficent to instal the bare bones communication backbone with no gui tools or packages.
the aim is to purely use ROS as a middleware between deepstream and various state machines and comms gateways between hardware interfaces.
Thank you.
Ganindu.
p.s
I tried the build farm way it seem to work only takes about 100 mb it seems
ganindu@ubuntu:/usr/share$ du -h -d 1 /opt/ros/
107M /opt/ros/humble
107M /opt/ros/
