Please provide the following info:
NVIDIA DRIVE™ Software 10.0 (Linux) Target Operating System
Linux Hardware Platform
NVIDIA DRIVE™ AGX Xavier DevKit (E3550) SDK Manager Version
1.4.0.7363 Host Machine Version
native Ubuntu 18.04
Hey,
I have a can-based radar, is it posible to use it with DriveWorks?
Do I have to implement a custom radar plugin with Comprehensive Sensor Plugin Framework, or is this Framework only for ethernet-based radar?
Can you provide a template radar implementation or can you say what I have to implement?
Thank you for your reply. My Sensor is not supported out of the box.
I’ve read the documentation and have some questions:
Which functions do I have to implement in which order?
Do I have to implement the DriveWorks User API or Plugin API?
Is a Template available?
Do I have to implement function defined in Common Interface or Radar Plugin? Or both?
Then i found the file “CUSTOM LIDAR/RADAR INTEGRATION WITH DRIVEWORKS SDK” there is an Example code file SAL_Radar_plugin_template.c: and a Example header file SAL_Radar_plugin_template.h. Can I use them or are they only for the ip protool? And do they differ from the documenation Custom Radars (comprehensive)?
