Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
we are thinking about buying the supported ARS430 radar sensor by Continental. Therefore, we have several questions:
Do you have already recorded replay data from the radar sensor? If yes, is possible to use this data to run it with the radar replay sample or any other sample? In this way we could analyze the data and have a look at whether our needs are met.
According to the Continental website, the ARS430 is able to detect objects and generate object lists. Is it possible to access these object lists in DriveWorks? Can you point to where and how the information from the radar sensor can be read using the DriveWorks API?
Can the sensor in combination with DriveWorks return relative velocities to other objects?
Thank you in advance for answering the above questions!
Is /usr/local/driveworks-4.0/data/samples/sensors/radar/conti/ars_v4.bin what you’re looking for? You can run sample_radar_replay to replay it by default.
Also, thank you for answering the first question from my initial post. Could you also answer the second and third question, too? That would help us a lot.
Please refer to the source of sample_radar_replay (/usr/local/driveworks/samples/src/sensors/radar/radar_replay/main.cpp) and Radar Sensor document for the other questions. Thanks.
Never mind, I found the download site for Drivworks 4.0 ( NVIDIA DRIVE Downloads | NVIDIA Developer). I will now install Driveworks 4.0 and let you know if it works with my GTX 1060.
Dear @kn10,
You can try uninstalling the old release(DRIVE SW 10.0) from host with sdkmanager and install DRIVE OS 5.2.6 first to check DW 4.0. Please file a separate topic if you face any issues.
