the ov-cache consumes ~20GB on my machine…
13.3GB is related to “Kit”… even to version that or not installed anymore. Which of those folders are save to delete, if I need to free up some space?
Carl
Carl
Should be safe to cleanup. These are the ${cache} folders listed here: Tokens — kit-manual 104.0 documentation
Extension developers and users should be ok with this data getting cleaned up between sessions.
Hi @mati-nvidia,
thank you very much for that info. I was a little bit concerned about those older kit-folders, because I have not yet understood what kit versions other apps like create use. Do they always use the newest installed version, or do they bring their own version. And if yes, how to determine which version of kit is used (for example) by create? Because I wont delete the cache for kit versions that are still in use…
But anyway… I’ve deleted all caches but that from the latest version and it all works fine :-)
Carl
