I am having problem with my micro usb port. I can’t see it in usb devices when i do ‘lsusb’. When i check it with multimeter i voltage value on the port is zero. Is there another recovery port or another way to flash jetson? I would be very glad for any recommendation.
When in device mode (which is what recovery mode is) the port is not supposed to supply the +5V…in device mode it could be a consumer of +5V if not self-powered (but a Jetson is self-powered).
If you are sure you held down the recovery button while powering up or restarting power (the video does a nice job at showing this), then look for this having output on your host:
lsusb -d 0955:7c18
If you use a micro-A cable instead of a micro-B cable (an OTG port accepts either), then this will fail…micro-A is used when the Jetson is acting as a host, micro-B is used when acting as a device. Flash must be with micro-B. The cable supplied with the Jetson is a micro-B.
Is this information documented somewhere? After poring through the manual, I was unable to find it - but your post helped me resolve my problem (especially regarding the Micro-A (host) vs Micro-B (client) distinction). If not, I would recommend to the Admin to pass it along to be properly documented.
The procedure for flash contains the instructions, but not the theory. Part of the reason I am aware of this is that I have an interest in USB protocols and custom USB hardware, but most people would not have an interest in that.
