@fzg7919 This usage is expected for now. A fix is planned for the next version to have a another option to upload folders.
I am running isaac_sim-2021.1.1 and also have the same issue. here is my log, thanks
kit_20210914_101614.log (175.2 KB)
| NVIDIA-SMI 460.91.03 Driver Version: 460.91.03 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce RTX 208⊠On | 00000000:08:00.0 On | N/A |
| 45% 50C P2 94W / 300W | 3238MiB / 11016MiB | 38% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1223 G /usr/lib/xorg/Xorg 38MiB |
| 0 N/A N/A 1357 G /usr/bin/gnome-shell 15MiB |
| 0 N/A N/A 18737 G /usr/lib/xorg/Xorg 448MiB |
| 0 N/A N/A 18832 G /usr/bin/gnome-shell 94MiB |
| 0 N/A N/A 20073 G âŠgAAAAAAAAA --shared-files 63MiB |
| 0 N/A N/A 27932 G /snap/blender/624/blender 68MiB |
| 0 N/A N/A 28835 C+G âŠsaac_sim-2021.1.1/kit/kit 2464MiB |
@Sheikh_Dawood I want to try that, but when I hit the launch button it doesnât open anything so I can select headless WebSocket launcher.
@morteza.dianatfar Try running that command in a terminal. It will run the headless Isaac Sim with websockets directly, without using the launcher.
@BobbyChen From your logs, it looks like you are missing a local install of Nucleus. You can install it using command line with the downloaded Nucleus installer if you are running headless or you can install it via the Omniverse Launcher.
could you give any help on how to do it?
Using terminal, go to the installed Isaac Sim package at ~/.local/share/ov/pkg/isaac_sim-2021.1.1. Then run
./isaac-sim.headless.websocket.sh
I tried the instruction i get error message which i attached to the word document.Isaac_socket_error.docx (13.2 KB)
It looks like a driver issue. Can you post the output of nvidia-smi?
Try installing the drivers using the .run file.
Hereâs a useful guide.
https://docs.omniverse.nvidia.com/prod_launcher/prod_kit/linux-troubleshooting.html
Please also check that the GPU is detected in the VM. This may not work if the VM does not support GPU passthrough.
Posting here because it seems to be the most recently updated thread with Isaac Sim launch issues. [Please let me know if I should create a new topic for this instead.]
Iâm facing the same general problems as the original poster.
- Isaac Sim doesnât launch from the Launcher â thereâs a blank window that shows up for a fraction of a second (and then vanishes)âŠthen, nothing.
- Running from the shell results in a floating point exception (see below).
Here is my setup:
System:
- Ubuntu 20.04
- Memory: 64 GB
- 2 GPUs:
- Titan Xp
- RTX 2080 Ti
NVidia:
- Driver: 470.63.01 (installed via sudo ubuntu-drivers autoinstall).
- Launcher: 1.3.2
- Isaac Sim: 2021.1.1
- Cache: 2021.2.1
- Nucleus: 2021.2.2
Output from terminal:
$>./isaac-sim.sh -vv
⊠yields this error:
2021-10-05 20:26:31 [85,353ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-10-05 20:26:31 [85,356ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long const&>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long const&)
2021-10-05 20:26:31 [85,359ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbOnPluginRegisterEx
2021-10-05 20:26:31 [85,361ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!std::__future_base::_State_baseV2::_M_is_deferred_future() const
2021-10-05 20:26:31 [85,365ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!void std::this_thread::sleep_for<long, std::ratio<1l, 1000000l> >(std::chrono::duration<long, std::ratio<1l, 1000000l> > const&)
2021-10-05 20:26:31 [85,368ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()
2021-10-05 20:26:31 [85,372ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-10-05 20:26:31 [85,376ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!carbOnPluginPostShutdown
2021-10-05 20:26:31 [85,376ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-10-05 20:26:31 [85,380ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-10-05 20:26:31 [85,380ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Floating point exception (core dumped)
Attached is my log file.kit_20211005_132505.log (189.4 KB). As an aside, in the log, you will also see multiple occurrences of this error:
ERROR: numba 0.54.0 has requirement numpy<1.21,>=1.17, but you'll have numpy 1.21.2 which is incompatible.
Output from ânvidia-smiâ:
Tue Oct 5 13:51:56 2021
| NVIDIA-SMI 470.63.01 Driver Version: 470.63.01 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA TITAN Xp Off | 00000000:01:00.0 On | N/A |
| 24% 43C P5 28W / 250W | 1628MiB / 12192MiB | 0% Default |
| | | N/A |
| 1 NVIDIA RTX 2080Ti Off | 00000000:02:00.0 Off | N/A |
| 27% 35C P8 11W / 250W | 11MiB / 11019MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1371 G /usr/lib/xorg/Xorg 102MiB |
| 0 N/A N/A 2108 G /usr/lib/xorg/Xorg 824MiB |
| 0 N/A N/A 2233 G /usr/bin/gnome-shell 217MiB |
| 0 N/A N/A 67452 G .../usr/bin/bin/prusa-slicer 187MiB |
| 0 N/A N/A 346699 G ...AAAAAAAAA= --shared-files 3MiB |
| 0 N/A N/A 356494 G ..._99083.log --shared-files 57MiB |
| 0 N/A N/A 365376 G ...AAAAAAAAA= --shared-files 215MiB |
| 0 N/A N/A 380032 G gnome-control-center 3MiB |
| 1 N/A N/A 1371 G /usr/lib/xorg/Xorg 4MiB |
| 1 N/A N/A 2108 G /usr/lib/xorg/Xorg 4MiB |
Output from âsudo lshw -shortâ:
H/W path Device Class Description
system MS-7B44 (Default string)
/0 bus Z370M GAMING PRO AC (MS-7B44)
/0/0 memory 64KiB BIOS
/0/39 memory 64GiB System Memory
/0/39/0 memory 16GiB DIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0.5 ns)
/0/39/1 memory 16GiB DIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0.5 ns)
/0/39/2 memory 16GiB DIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0.5 ns)
/0/39/3 memory 16GiB DIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0.5 ns)
/0/3f memory 384KiB L1 cache
/0/40 memory 1536KiB L2 cache
/0/41 memory 12MiB L3 cache
/0/42 processor Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz
/0/100 bridge 8th Gen Core Processor Host Bridge/DRAM Registers
/0/100/1 bridge Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16)
/0/100/1/0 display GP102 [TITAN Xp]
/0/100/1/0.1 multimedia GP102 HDMI Audio Controller
/0/100/1.1 bridge Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8)
/0/100/1.1/0 display TU102 [GeForce RTX 2080 Ti]
/0/100/1.1/0.1 multimedia TU102 High Definition Audio Controller
/0/100/1.1/0.2 bus TU102 USB 3.1 Host Controller
/0/100/1.1/0.2/0 usb3 bus xHCI Host Controller
/0/100/1.1/0.2/1 usb4 bus xHCI Host Controller
/0/100/1.1/0.3 bus TU102 USB Type-C UCSI Controller
/0/100/8 generic Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
How do I get this working?
Hi @safdar.kureishy. I believe your issue is a different one. It could be related to the Titan Xp that is not supported.
Try running with this flag to ignore the Titan Xp or try remove the Titan Xp GPU.
â/renderer/activeGpu=1
I do not see the numba error in the log. Try changing the version to 0.51.2.
Thanks for the prompt response, @Sheikh_Dawood Sheikh_Dawood.
I downgraded numba to the one you mentioned:
$> pip install numba==0.51.2
And, I then ran isaac-sim with the GPU option you specified, as follows:
$> ./isaac-sim.sh -vv â/renderer/activeGpu=1
But I still see the following errors across the output/log file:
2021-10-06 19:19:15 [917ms] [Error] [carb.graphics-vulkan.plugin] Failed to find a graphics and/or presenting queue.
2021-10-06 19:19:15 [917ms] [Error] [omni.kit.renderer.plugin] Failed to create swapchain
2021-10-06 19:19:15 [1,748ms] [Error] [rtx.postprocessing.plugin] createDLSSContext error: unable to initialize context. Optional DLSS feature is disabled.
2021-10-06 19:19:18 [4,414ms] [Error] [carb.python] Could not find nucleus server with /Isaac folder
2021-10-06 19:11:49 [51,581ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-10-06 19:11:49 [51,583ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long const&>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long const&)
2021-10-06 19:11:49 [51,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbOnPluginRegisterEx
2021-10-06 19:11:49 [51,588ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!std::__future_base::_State_baseV2::_M_is_deferred_future() const
2021-10-06 19:11:49 [51,593ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!void std::this_thread::sleep_for<long, std::ratio<1l, 1000000l> >(std::chrono::duration<long, std::ratio<1l, 1000000l> > const&)
2021-10-06 19:11:49 [51,597ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()
2021-10-06 19:11:49 [51,601ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-10-06 19:11:49 [51,604ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!carbOnPluginPostShutdown
2021-10-06 19:11:49 [51,604ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-10-06 19:11:49 [51,610ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-10-06 19:11:49 [51,610ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Here are the âWarningsâ across the same file:
$> cat kit_20211006_123530.log | grep "Warning"
2021-10-06 19:35:30 [73ms] [Warning] [omni.ext.plugin] Extension with the same id is already registered. ext_id: 'omni.kit.xr-1.0.0', ext 1: '/home/safdar/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.xr', ext 2: '/home/safdar/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.xr'
2021-10-06 19:35:30 [359ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-RTX GPU: NVIDIA TITAN Xp
2021-10-06 19:35:30 [360ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-RTX GPU: NVIDIA TITAN Xp
2021-10-06 19:35:31 [1,281ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] '/home/safdar/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
2021-10-06 19:35:31 [1,734ms] [Warning] [carb.graphics-vulkan.plugin] NGX does not support feature SuperSampling.Available.
2021-10-06 19:35:31 [1,734ms] [Warning] [rtx.postprocessing.plugin] NGX does not have DLSS feature. Check nvngx_dlss.dll is available.
2021-10-06 19:35:32 [2,017ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [rtx::raytracing::Subsurface v0.1] (plugin: rtx.raytracing.plugin), by client: carb.scenerenderer-rtx.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
2021-10-06 19:35:34 [4,367ms] [Warning] [omni.client.plugin] Tick: authentication: Could not connect to discovery service at "wss://localhost/omni/discovery"
2021-10-06 19:35:34 [4,369ms] [Warning] [omni.client.plugin] Tick: authentication: Discovery(ws://localhost:3333): Credentials service not found!
2021-10-06 19:35:34 [4,370ms] [Warning] [carb.python] default server omniverse://localhost does not have /Isaac folder
2021-10-06 19:35:34 [4,370ms] [Warning] [carb.python] /isaac/nucleus/default not specified in json config or via --/isaac/nucleus/default="omniverse://my-nucleus-server" command line
2021-10-06 19:35:34 [4,370ms] [Warning] [carb.python] Attempting to locate server from previously saved servers...
2021-10-06 19:35:34 [4,370ms] [Warning] [carb.python] /persistent/app/omniverse/savedServers setting not found
2021-10-06 19:35:34 [4,370ms] [Warning] [carb.python] /persistent/app/omniverse/mountedDrives setting not found
2021-10-06 19:35:34 [4,370ms] [Warning] [carb.python] No saved servers
2021-10-06 19:35:34 [4,380ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] Failed to load plugins, folder doesn't exist: '/home/safdar/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.ansel/bin'.
2021-10-06 19:35:34 [4,380ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] '/home/safdar/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.ansel/bin/*.plugin' in '[[native.plugin]]' was not found.
The latest log file is attached again.kit_20211006_121914.log (171.7 KB)
Some more info about my PCI cards, in case it helps:
$> lspci
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07)
00:01.1 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) (rev 07)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
00:14.2 Signal processing controller: Intel Corporation 200 Series PCH Thermal Subsystem
00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI #1
00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode]
00:1b.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #17 (rev f0)
00:1b.2 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #19 (rev f0)
00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #1 (rev f0)
00:1c.4 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #5 (rev f0)
00:1c.6 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #7 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Z370 Chipset LPC/eSPI Controller
00:1f.2 Memory controller: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
00:1f.3 Audio device: Intel Corporation 200 Series PCH HD Audio
00:1f.4 SMBus: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-V
01:00.0 VGA compatible controller: NVIDIA Corporation GP102 [TITAN Xp] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP102 HDMI Audio Controller (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti] (rev a1)
02:00.1 Audio device: NVIDIA Corporation TU102 High Definition Audio Controller (rev a1)
02:00.2 USB controller: NVIDIA Corporation TU102 USB 3.1 Host Controller (rev a1)
02:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU102 USB Type-C UCSI Controller (rev a1)
04:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
06:00.0 USB controller: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller
07:00.0 USB controller: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller
Here are the ânvidiaâ-related processes running on my machine prior to launching isaac-sim:
$> ps -ef | grep "nvidia"
root 862 2 0 Oct02 ? 00:00:00 [nvidia-modeset/]
root 863 2 0 Oct02 ? 00:00:00 [nvidia-modeset/]
root 865 2 0 Oct02 ? 00:13:28 [irq/148-nvidia]
root 951 2 0 Oct02 ? 00:00:26 [irq/149-nvidia]
nvidia-+ 1206 1 0 Oct02 ? 00:00:00 /usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose
safdar 4137 2010 1 Oct02 ? 01:01:39 /opt/google/chrome/chrome https://developer.nvidia.com/omniverse/driver
root 586088 2 0 11:19 ? 00:00:00 [nvidia]
root 586159 2 0 11:19 ? 00:00:00 [nvidia]
I also tried to create a Nucleus service, since the warnings alluded to that, but the nucleus setup hourglass keeps spinning, and the corresponding log contains these errors/warnings:
$> cat omni.server.app.log | grep -E "(Error|Warning)"
2021-10-06 19:45:31 [19ms] [Warning] [carb] [596671] ../../../source/framework/FrameworkImpl.cpp:acquireInterface():702: Acquiring non optional plugin interface which is not listed as dependency: [carb::dictionary::IDictionary v1.0] (plugin: (null)), by client: omni.core. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
2021-10-06 19:45:31 [226ms] [Error] [omni.core] [596692] ../../../source/plugins/common/ChildProcess.cpp:stderrReadCallback():30: From process ./omni-lft-service/omni-lft-service:DATA_DIR: /home/safdar/.local/share/ov/data/serverBundled - using PyInstaller's runtime dir with resolvers
2021-10-06 19:45:31 [248ms] [Error] [omni.core] [596692] ../../../source/plugins/common/ChildProcess.cpp:stderrReadCallback():30: From process ./omni-lft-service/omni-lft-service:2021-10-06 12:45:31,938 - system_log - INFO - reconnecting ...
2021-10-06 19:45:31 [250ms] [Error] [omni.core] [596692] ../../../source/plugins/common/ChildProcess.cpp:stderrReadCallback():30: From process ./omni-lft-service/omni-lft-service:2021-10-06 12:45:31,940 - system_log - INFO - [Errno 111] Connect call failed ('127.0.0.1', 3007)
2021-10-06 19:45:32 [1,252ms] [Error] [omni.core] [596692] ../../../source/plugins/common/ChildProcess.cpp:stderrReadCallback():30: From process ./omni-lft-service/omni-lft-service:Traceback (most recent call last):
ConnectionRefusedError: [Errno 111] Connect call failed ('127.0.0.1', 3007)
idl.connection.transport.TransportError: [Errno 111] Connect call failed ('127.0.0.1', 3007)
2021-10-06 19:45:32 [1,255ms] [Error] [omni.core] [596692] ../../../source/plugins/common/ChildProcess.cpp:stderrReadCallback():30: From process ./omni-lft-service/omni-lft-service:2021-10-06 12:45:32,945 - system_log - INFO - [Errno 111] Connect call failed ('127.0.0.1', 3007)
2021-10-06 19:45:33 [2,024ms] [Warning] [carb] [596676] ../../../source/framework/FrameworkImpl.cpp:acquireInterface():702: Acquiring non optional plugin interface which is not listed as dependency: [carb::dictionary::IDictionary v1.0] (plugin: (null)), by client: omni.core. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
2021-10-06 19:45:33 [2,024ms] [Warning] [carb] [596676] ../../../source/framework/FrameworkImpl.cpp:acquireInterface():702: Acquiring non optional plugin interface which is not listed as dependency: [carb::dictionary::ISerializer v1.0] (plugin: carb.dictionary.serializer-json.plugin), by client: omni.core. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
2021-10-06 19:45:33 [2,030ms] [Error] [carb] [596671] ../../../source/framework/FileSystem.cpp:moveImpl():792: File move failed: '/home/safdar/.nvidia-omniverse/logs/Nucleus/Access.log' -> '/home/safdar/.nvidia-omniverse/logs/Nucleus/Access_OLD.log' (No such file or directory)
2021-10-06 19:45:33 [2,030ms] [Error] [omni.server] [596671] ../../../source/plugins/omni.server/apilogging/deprecated/ApiLogging.cpp:resetApiLogFile():210: Failed to rename access log file '/home/safdar/.nvidia-omniverse/logs/Nucleus/Access.log' to '/home/safdar/.nvidia-omniverse/logs/Nucleus/Access_OLD.log'
2021-10-06 19:45:33 [2,257ms] [Error] [omni.core] [596692] ../../../source/plugins/common/ChildProcess.cpp:stderrReadCallback():30: From process ./omni-lft-service/omni-lft-service:Traceback (most recent call last):
2021-10-06 19:45:33 [2,259ms] [Error] [omni.core] [596692] ../../../source/plugins/common/ChildProcess.cpp:stderrReadCallback():30: From process ./omni-lft-service/omni-lft-service:2021-10-06 12:45:33,949 - system_log - INFO - connected
2021-10-06 19:45:33 [2,259ms] [Error] [omni.core] [596692] ../../../source/plugins/common/ChildProcess.cpp:stderrReadCallback():30: From process ./omni-lft-service/omni-lft-service:Server started
Are there any other command outputs I should include here, to shed light on why this is happening?
And, should I create a new topic for this? Or continue on this thread?
Greetings,
Isaac is not launching even if I try launching it through the terminal, here is the log
and this is the output of nvidia-smi
Hi, @abdulla.albreiki . Iâm afraid the Quadro T2000 is supported as it does not have RT cores. You will need an RTX capable GPU to run Isaac Sim.
Thanks @Sheikh_Dawood for the quick reply, you saved me a lot of debugging time
Well I can open it all from the command line I guess but please make this more stable on bare metal workstation and there is a lack of instructions or videos. Can you fix this problem???
Look everyone has this same problem. I have Ubuntu Installed.
I have Omniverse working in Ubuntu.
The first time I launched Isaac Sim it launched.
I did not have a Nucleus Server set up before that.
It did open up Isaac Sim the first time and I was able to see a robot arm demo.
Then it says that error about needing the Nucleus server and downloading and reuploading the sample.
However once you install the Nucleus Server you can not relaunch Isaac Sim.
So I can not launch Isaac Sim now. If i uninstall Nucleus, it still does not launch.
If I uninstall Isaac Sim restart reinstall Isaac Sim it does not launch.
Can you please simple fix this problem 1. So that I can completely uninstall Omniverse anytime and reinstall it properly.
Can you simple please fix this problem so that I can simply launch Isaac Sim I can not do so at all now like read above please.
Next time if I rewipe ubuntu totally then I will have nucleus installed before I install Isaac Sim
but it is pretty sad i can not simply run this program please help me.
I had to do many things just to get Ubuntu working, Disable Fast and Smart Boot, install Nvidia Drivers, just to get Omniverse working on Linux. Thanks, Cliff
Hi, apologies on the lack of instructions. We will be improving our documentation for the upcoming version.
Please provide the logs for the Isaac Sim App Launcher or Isaac Sim with the crash.
Isaac Sim should still run even without a local Nucleus installed.
You can uninstall Omniverse cleanly with this tool. Please exit the Launcher before running the Cleanup Tool.
https://docs.omniverse.nvidia.com/prod_launcher/prod_utilities/cleanup-tool.html
The same error that Isaac Sim did not start from Launcher happened with me. After a year, is there a fix or not?
@Robotawi Please provide more details on the Isaac Sim version you are trying and logs with the error.
Isaac-sim Version 2021.2.1
I am migrating my human demonstration data to the new version.
I encountered the same floating point exception thing across different runs at different times during the run
kit_20220831_010412.log (29.9 MB)
Uploading: kit_20220831_003850.logâŠ
kit_20220831_003118.log (20.5 MB)
