Isaac Sim Publishing Camera Topic in ROS 2, But No Messages Received
Isaac Sim Version
[o] 4.2.0
Operating System
[o] Ubuntu 22.04
Hi, I am following ROS2 Cameras — Isaac Sim Documentation this tutorial to publish my camera’s depth, RGB, and camera info.
I used the common omnigraph afforded and had set the camera prim properly.
The topic was published but I could not check the real data → it wasn’t valid to check it through rviz as you can see in the image.
What can be the problem? Should I publish the data through the script, will it work?
Please try with Isaac Sim 4.5.0
@yeon0857 , does a ros2 topic list show the corresponding topic being published? Have you followed the ROS 2 installation steps listed with Isaac Sim? Checking the frame also should help to verify if the image is being published correctly
I will close this topic since there is no new replies. But please feel free to open a new topic if the issue still persists.
