We are trying to install Jetpack 4.3 on our Xavier Dev Board.
We updated the Software Manager 1.0.0.5517, then we downloaded Jetpack 4.3, connected to the correct USB port, set Xavier into recovery mode, started the flash process.
After the flash is done (“success”), Software Manager prompts that we now must configure the Ubuntu OS on the Xavier.
When switching to the Xavier Screen we see Text Bootup Display. It stops with the message:
“please complete system configuration setup on the serial port provided by Jetson’s USB device mode connection…”
then some success messages.
Then it waits forever with:
(1 of 2) a start job is running for end user configuration after initial OEM installation (Debconf UI)
alternating with
(2 of 2) a start job is running for end user configuration after initial OEM installation
this stays forever.
Help appreciated.
